DC 252 colour mis-registration
  • adeyemi
    • 379
    I have a serious color mis-registration issue on DC252. Reg control sensor check cycle comes up negative for all the sensors, hence registration measurement cycle and registration control setup cycle fails. I have cleaned the ROS, the MOB sensors and the IBT assembly. What else do I need do? Thanks
    Dgtal
  • johnner66
    • Mar 2009
    • 265
    you got the brith cert. for the m/c set the setting using the brith cert, list or try change the mob
    • adeyemi
      • 379
      Thanks for your response, but what's brith cert??
      Dgtal
      • davidj7
        • 1107
        default nvm settings . It should be inside the door or in a paper tray.
        a machine is only as good as your tech : source:screwtape ; the scary one
