Xerox C226 error H5-01
  • jonbonse
    • Jun 2009
    • 737
    Hey all
    I need to know how to enter service mode to reset error H5-01. . . . .
    I think its a fuser error but really could do with the service manual if anyine can point me in the right direction to get one. . . .
    Any help on the error code too would be appreciated.
    Many thanks
  • bojans
    • 1313
    This is how to enter Diag mode
    1. #/P (program key)
    2. * (Asterisk key)
    3. C (clear key)
    4. * (Asterisk key)
    The following message is displayed : input a main program number by the 10-keypad, and press start.
    I'll check about code
    • bojans
      • 1313
      H5-01 Paper Exit Jam - procedure
      Ensure that all of paper is removed, and the Lower Fuser harness is correctly seated and not damaged.
      Ensure that the Fuser Assy is installed correctly.
      H3,H4,H5 Fault Clearance procedure
      1. Enter Diag mode
      2. Enter main program 14
      3. Select EXECUTE
      NO
      YES
      Good luck
      • jonbonse
        • Jun 2009
        • 737
        2. * (Asterisk key)
        3. C (clear key)
        4. * (Asterisk key)
        Hi bojans
        Do these instructions for diagnostics work on the Sharp AR337? They seem identical. . .
        • bojans
          • 1313
          I really don't know. Never worked on Sharp AR337...
          • wtroll
            • May 2008
            • 85
            Originally posted by jonbonse
            Hi bojans
            Hallo,
            You are right, the Xerox C226 is a Sharp machine (unfortunately not a great project...) called Sharp AR-C260.
            Good luck!
