Error 9-345 on a DC12
  • brenni
    • Sep 2008
    • 38
    Hi,
    as the title says, thats my problem.
    I already hat the ITB out and cleaned as much as i can, no success.
    any ideas what to do?
  • bojans
    • 1313
    Clean/replace IBT cleaner retract clutch PN 121K17940.
    I used to clean it with alcohol, and it worked for a long time..
    • brenni
      • Sep 2008
      • 38
      thats the clutch inside machine where the ITB sildes in, correct?
      • bojans
        • 1313
        yes it's inside.
        Maybe you'll find hard to reach it for the first time, but i believe you'll succeed.
        BR
        • brenni
          • Sep 2008
          • 38
          i see it; its a hole in the back of thet machine where part of ITB sildes in. inside i see/feel the drive/clutch.
          how did you clean in there? any tool you used?
          • bojans
            • 1313
            You must remove it from machine. Need only screwdriver. And then clean it with film remover or alcohol.
            I'm 100% sure that clutch is your problem, but just saw in Eureka that P/J 717 connector might be loose and cause this fault.
            • brenni
              • Sep 2008
              • 38
              ok thanks.
              can you please give me 2 short sentences how to remove it; i would be very thankful.
              where i find the 717 connector to check?
              • bojans
                • 1313
                I can't explain in 2 sentences
                Just remove back cover, then black fly wheel and so on... You have to remove many parts to reach retract clutch.
                About P/J connector, this is from Eureka:
                This connector is located on an air duct on the bottom right hand corner of the IOT Drive PWB and acts as a double plug to connect on one side to the connector of the IBT Cleaner Blade home position sensor and the other side to a connector that leads to the IOT Drive PWB.
