Just remove back cover, then black fly wheel and so on... You have to remove many parts to reach retract clutch.
About P/J connector, this is from Eureka:
This connector is located on an air duct on the bottom right hand corner of the IOT Drive PWB and acts as a double plug to connect on one side to the connector of the IBT Cleaner Blade home position sensor and the other side to a connector that leads to the IOT Drive PWB.
