DC252 Premature Drum failures
  • adeyemi
    • 378
    Please can anyone tell me why the colour drums on my DC252 are consistently failing before timing out. They fail when they are still at very high percentages like 80%, even 90%, i.e only 10-20 % usage!! This has happened for several sets of the colour drums. Black is ok.
    Dgtal
  • kalindd
    • Jun 2008
    • 192
    May be the cleaning system is not working, the motor that cleans the corotron is used also to push a black plastic rod, that pushes the cleaning system.
    • adeyemi
      • 378
      Thanks Kalindd, you have a very good point on this, i didn't think of it...i'll check it up, thanks.
      Dgtal
      • davidj7
        • 1107
        i am having similar problems with the same drum but in DC5000. i get lines in process direction after 1000k. the lines appear on the charging rod and moves to the drum.The drum unit goes in 5k
        a machine is only as good as your tech : source:screwtape ; the scary one
