Once installed, chip will automatically reset it's counter every time you turn printer off or remove drum unit from printer, and does not require any attention from the user throughout the life of the printer.
Chips can be removed from printer or copier at any time and installed into another printer or copier of same model.
No need any tools for installation!
No need to replace or reprogram chip at all!
No need a hardware resetter or any special software!
Your printer will never be blocked due to ending of image drum counter!
Just install-and-forget!
You can use it if the drum in image drum unit is in good condition, but chip ran out of life, or if you using compatible drums instead bying new image drum unit.
4 NEVER-ENDING autoresettable chips Xerox 3535 M24 4 NEVER-ENDING autoresettable chips for Xerox 7700 - eBay (item 250613507950 end time Jul-10-10 09:26:58 PDT)
Xerox Phaser 7700
4 NEVER-ENDING autoresettable chips for Xerox 7750 - eBay (item 250618769076 end time Jul-19-10 06:15:50 PDT)
Xerox Phaser 7750
4 NEVER-ENDING autoresettable chips for Xerox 7760 - eBay (item 250618769708 end time Jul-19-10 06:17:04 PDT)
Xerox Phaser 7760
NEVER-ENDING autoresettable chip for Xerox DC 12, 50 - eBay (item 250612829024 end time Jul-09-10 03:34:19 PDT)
Xerox DC 12, 50
4 NEVER-ENDING autoresettable chips Xerox WC pro 2128 - eBay (item 250638953958 end time Jul-24-10 04:36:42 PDT)
Xerox Workcentre pro C2128, C2636, C3545
Xerox Phaser 7700
Xerox Phaser 7750
Xerox Phaser 7760
Xerox DC 12, 50
