Dc 242 - 252 - 260 error code list post, i cannott find it.
  • hector787
    • Jul 2025
    I had on my other PC, saved on my favorites, a post with a error code list from the DC 242 - 252 - 260
    now that pc is broken and i cant se my hard disk , well im trying to find that thread again and i cant,
    if someone knows the link please let me know
    thanks
  • kandod
    • Mar 2010
    • 58
    That's from that thread witch is in Russian: Xerox DocuColor DC 240 250 242 252 260
    002-770 RAP Insufficient HDD capacity while processing the job template within a job.
    003-318 RAP IIT software failure.
    003-319 RAP IIT Video Driver Detection Fail.
    003-320 RAP IIT-ESS Communication Fail 1.
    003-321 RAP IIT-ESS Communication Fail 2.
    003-322 RAP IIT-ESS Communication Fail 3.
    003-323 RAP IIT-ESS Communication Fail 4.
    003-324 RAP IIT-ESS Communication Fail 5.
    003-325 RAP IIT-ESS Communication Fail 6.
    003-326 RAP IIT-ESS Communication Fail 7.
    003-327 RAP IIT-ESS Communication Fail 8.
    003-328 RAP IIT-ESS Communication Fail 9.
    003-329 RAP IIT-ESS Communication Fail 10.
    003-330 RAP IIT-ESS Communication Fail 11.
    003-331 RAP IIT-ESS Communication Fail 12.
    003-332 RAP IIT-ESS Communication Fail 13.
    003-333 RAP IIT-ESS Communication Fail 14.
    003-334 RAP IIT-ESS Communication Fail 15.
    003-335 RAP IIT-ESS Communication Fail 16.
    003-336 RAP IIT-ESS Communication Fail 17.
    003-337 RAP IIT-ESS Communication Fail 18.
    003-338 RAP IIT-ESS Communication Fail 19.
    003-339 RAP IIT-ESS Communication Fail 20.
    003-340 RAP IIT-ESS Communication Fail 21.
    003-341 RAP IIT-ESS Communication Fail 22.
    003-342 RAP IIT-ESS Communication Fail 23.
    003-343 RAP IIT-ESS Communication Fail 24.
    003-344 RAP Power on hotline failure.
    003-345 RAP X PIO Unmatch Fail 1.
    003-346 RAP X PIO Unmatch Fail 2.
    003-750 RAP Book Duplex-Insufficient Docs.
    003-751 RAP Under PANTHER Capacity (Scan).
    003-752 RAP This status code is displayed if 600dpi cannot be scanned (DADF).
    003-753 RAP This status code is displayed if over 300dpi cannot be scanned (DADF).
    003-754 RAP S2X Recoverable Error.
    003-755 RAP S2X Command Error.
    003-757 RAP This status code is displayed if over 400dpi cannot be scanned (DADF).
    003-760 RAP Scan Settings Error.
    003-761 RAP Incorrect Paper Tray Size.
    003-763 RAP Adjustment Chart Not Found.
    003-764 RAP Adjustment Chart Not Found.
    003-780 RAP Scan Image Compression Error.
    003-795 RAP AMS Limit Error.
    003-940 RAP DAM Memory is insufficient.
    003-942 RAP Document Size Error.
    003-944 RAP Image Repeat Count Fail.
    003-946 RAP Copy Vertical/Horizontal Difference (APS).
    003-947 RAP Replaced Original Count Error.
    003-948 RAP Replaced Original Mismatch.
    003-952 RAP Return Documents Color mismatch.
    003-955 RAP Documents Size Exchange Error.
    003-956 RAP Documents Size Unknown Error.
    003-963 RAP No APS Object Tray.
    003-965 RAP ATS/APS No Paper. There is no paper in the trays that can be selected with APS.
    003-966 RAP AATS/APS No Destination Error.
    003-968 RAP Punch Position Error.
    003-969 RAP Punch Size Error.
    003-972 RAP Maximum Stored Page Over Flow.
    003-973 RAP Every Direction Difference.
    003-974 RAP Next Original Specification.
    003-977 RAP Document Miss Match (Multi Scan).
    003-978 RAP Color Document Mismatch (Multi Scan).
    003-980 RAP Staple Position Error.
    003-981 RAP Staple Size Error.
    003-982 RAP IITsc HDD Access Error.
    005-121 RAP DADF Feed Sensor ON Jam.
    005-122 RAP DADF Simplex/Side 1 Pre Reg Sensor ON Jam.
    005-123 RAP DADF Simplex/Side 1 Reg Sensor ON Jam.
    005-124 RAP DADF Lead Reg Sensor ON Jam.
    005-125 RAP DADF Reg Sensor OFF Jam.
    005-126 RAP DADF Out Sensor ON Jam.
    005-127 RAP DADF Out Sensor OFF Jam.
    005-128 RAP DADF Exit Sensor 1 ON Jam (Simplex Mode).
    005-129 RAP DADF Exit Sensor 1 OFF Jam (Simplex Mode).
    005-130 RAP DADF Invert Sensor ON Jam (Duplex Mode).
    005-131 RAP DADF Invert Sensor On Jam (Inverting).
    005-132 RAP DADF Invert SNR on Jam 2.
    005-133 RAP DADF Invert Sensor OFF Jam.
    005-134 RAP DADF Invert SNR off Jam (Inv).
    005-135 RAP DADF Pre Reg Sensor ON Jam (Invert).
    005-136 RAP DADF Reg Sensor ON Jam (Invert).
    005-137 RAP DADF Exit Sensor 2 ON Jam.
    005-138 RAP DADF Exit Sensor 1 ON Jam.
    005-139 RAP DADF Invert SNR off Jam.
    005-141 RAP DADF Feed Sensor OFF Jam.
    005-142 RAP DADF Exit Sensor 1 OFF Jam (Duplex Mode).
    005-143 RAP DADF Exit Sensor 2 OFF Jam.
    005-144 RAP DADF Too First Pre Reg Sensor ON Jam.
    005-145 RAP DADF Reg Sensor Off Jam (Invert).
    005-146 RAP DADF Pre Reg Sensor Off Jam.
    005-147 RAP DADF Pre Reg Sensor Off Jam (Invert).
    The rest of codes can be read on the page the above link leads to.
