work centre pro 32
  • rasman67
    • Jun 2025
    work centre pro 32
    I have a customer that has a wcp 32 that the fuser doesn't heat up and after about 10 min on the screen says power off the machine by using the white switch.customer says no codes come up. If anyone could help with this problem I would appreciate it.
    Thanks In advanced
  • JustManuals
    • Jan 2006
    • 9838
    This Parts & Service manual can now be purchased for $11.77 and downloaded immediately after payment from The Internet's largest collection of manuals
    Paul@justmanuals.com
    • copytech200X
      • 264
      check with customer this things happen after paper jam?i suggested removed fuser assy and clear all torn paper inside fuser due blocking thermister to sense heat roll temperature..good luck
      • rasman67
        Will the paper jam make the fuser not even warm up at all? The fuser lamps are good.
        Thanks Again
        • Milo Wilson
          • 499
          Try replacing the fuser fan assy, that can cause a similar problem
