Xerox WC4150, cycles up, panel lights, then goes out, repeat.....
  • Ducttape n Glue
    • 195
    Xerox WC4150, cycles up, panel lights, then goes out, repeat..... the UI panel only ever glows blue , machine whirrs up then down and lights out, over and over and over again>>>> any ideas?
    THX
  • gregoryk
    L.V.P.S.
    • pal.xerox
      Try to remove the HDD and then restart and short the bettry to remove cn27 for 1 minut.
      • tech9
        • 216
        remove hdd and hdd pwb completely and try and see if it boots if it does defective hdd or hdd pwb
        • Ducttape n Glue
          • 195
          could you explain this in alittle more detail. CN27?
          • Ducttape n Glue
            • 195
            Ok, that did allow the unit to power up. So either the hdd or its pwb.
            • Ducttape n Glue
              • 195
              Plugged it all back in and now says System Unavailable
              • tech9
                • 216
                More likely the HDD they go corrupt and need reformatting have done loads of 4150 with this problem.
                • Ducttape n Glue
                  • 195
                  The 4250/60 shows the ability to reformat within the diagnostics but not the 4150.
                  • tech9
                    • 216
                    Thats right it has to be done manually i.e remove from machine placed into a 2.5 hdd caddy enclosure and and connected to a laptop/pc and use an application called swissknife which is a free download.
                    • artphil
                      • Aug 2008
                      • 155
                      The hd's of the machines are really shitty.
                      Out of 10 machines i had to format/replace 8 hd's
                      Kid regards,
                      Artphil
                      • Ducttape n Glue
                        • 195
                        Thanks guys , reformatting the HDD did the trick...we'll play with it today and make sure all is ok.
                        • TEKK09
                          • 142
                          Re: Xerox WC4150, cycles up, panel lights, then goes out, repeat.....
                          And when you reformat, which format do you use (Fat32, EXT4, NTFS etc ??)
                          Also does anyone know how often the HD is so far gone it has to be replaced?
                          Thanks.
