DC250 Regi con setup
  • Jake2o
    • Dec 2007
    • 325
    When I run DC675 from either the PWS or the UI it goes through the motions but does not record a value and the colour to colour registration remains all over the place.
    When I run DC671 I get NG's in all results including patterns
    Any ideas?
  • Milo Wilson
    • 503
    Clean the MOB sensor assy and then try again.
    • xcopytech
      • Aug 2006
      • 1794
      also check black drum corotoron.
      if this corotron is bad you also can have such problem.
      • Jake2o
        • Dec 2007
        • 325
        Thanks Xcopytech, I had changed the corotron not long ago so I changed the entire black drum and it worked fine.
        1 more small problem now is that the yellow is missing from the edge of the IB side to about 15mm in.
        I have checked Dev housing and it seems ok, Swapped the drums and that made no difference.
        I am no expert with these machines so any help is much appreciated.
        • xcopytech
          • Aug 2006
          • 1794
          maybe you can scan image and post it here
          • Jake2o
            • Dec 2007
            • 325
            Here it is,
            • xcopytech
              • Aug 2006
              • 1794
              clean ROS and all mirrors in it and think that your problem will be solved
