xerox 5016 code error U9
  • tecnoacre
    • May 2009
    • 29
    Hello, friends, I have a xerox 5016 which is presenting the code U9, I wonder what this error is and how to solve the problem.
  • Mr Spock
    Vulcan Inventor of Death
    • Aug 2006
    • 2064
    If this is the same as the 5018 then it is a pr belt hole issue and could be anything from a bad pr belt to a bad hvt power supply.
    • simple mind
      • Aug 2009
      • 39
      xerox 5016 / U9
      U9-0 HVPS Fail
      BSD-Reference:
      CH9.1 (Figure 1)
      Explanation
      A 500 ms cycle of HVPS#ERR=High was detected twice in a row.
      Procedure
      Close the Left Hand Cover and the Front Cover. Make sure that the Drum Cartridge and the Transfer Corotron are properly seated. Measure the voltages between P406-2 ( P/J406) (+)/P406-4(+)/P406-5(+) on the AIOC PWB and ground (-).
      The voltages are approximately +5VDC.
      YN
      Replace the AIOC PWB (PL 8.1) (REP 8.1.1) and the HVPS (PL 8.2) (REP 8.2.1) in that order.
      Execute diagnostics [09-04 HVPS ON (Low Voltage)].
      How to Enter the Diagnostic Mode) The voltages at P406-2 ( P/J406) (+)/P406-4 (+)/P406-5 (+) become 0.
      YN
      Replace the AIOC PWB (PL 8.1) (REP 8.1.1).
      Replace the HVPS (PL 8.2) (REP 8.2.1).
      The problem is solved.
      YN
      Measure the voltage between P406-1 ( P/J406) (+) on the AIOC PWB and ground (-).
      The voltage is approximately +5VDC.
      YN
      Check between J520-1 ( P/J520) and J406-1 ( P/J406) on the HVPS PWB for a short circuit.
      If there is no short, replace the HVPS (PL 8.2) (REP 8.2.1).
      Completed
      • tecnoacre
        • May 2009
        • 29
        check these items and will back to inform the outcome, but thank the information ja
        • copymaster2000
          • Dec 2007
          • 28
          This issue is related to HVPS or Faulty print Cartridge .Try replacing old cartridge if u have it or with a new one.
