Move Network Scan from one WC Pro 45 to another WC Pro 45?
  • mrfuser
    • 1626
    Is it possible to disable and remove the scan enablement from one Xerox Workcentre Pro 45 and install it on another?
    Kelly
  • Milo Wilson
    • 508
    I'm not quite sure. Do you have the code provided with the enablement kit?
    • adeyemi
      • 378
      The question is "can u use the license string for one on another?....the answer is yes. But there is usually no reason to do that because every WCP controller comes with its own. Hope you're not trying to use it on a WC controller...WC controllers don't come with the license, and they are different from WCP's 'cos u can't load the scan license string on them.
      Dgtal
      • mrfuser
        • 1626
        ACTUALLY, you can do many things that XEROX says you can't......... ;0)
        • copymachine
          • May 2009
          • 53
          You have to enter activation code. For example: 42758413
          • Goshe
            • Jul 2009
            • 118
            You can find few activation codes on this forum. I've tried almost all of them and they worked for dc535/545 wc pro35/55
