DOCUCOLOR 12
  • awest486
    • Jun 2025
    DOCUCOLOR 12
    Hello,
    I have a Docucolor 12 and it has started doing something strange. When I print or copy on the unit the prints are coming out with everything printing perfectly except for the last 1 inch of the of the image, it is coming out without all the colors, only the black tonor is used in that part of the image and it is a faint image. The separation of the correctly printed part of the image with all the colors and the 1 inch part of the image that is black and white and faint is abrupt, the image changes from good to bad instantly. When I print in black and white there is no problem, it is only when I print in color that the problem persist and it is no every copy that comes out bad, after every 4 or 5 bad copies a good copy will come out. This problem started 3 weeks ago. Any help will be appreciated.
  • JustManuals
    • Jan 2006
    • 9838
    This Parts & Service manual can now be purchased for $11.77 and downloaded immediately after payment from The Internet's largest collection of manuals
    Paul@justmanuals.com
    • kandod
      • Mar 2010
      • 58
      Can you post a scanned picture with the image quality problem?
      manuals4you, what manuals for DC12 are you offering, I saw none available at your site, the only one I know of is in EDOC format for use with PWS, please be more specific where to look for Service Manual in some other format.
      • awest486
        IMAGES
        Here are the files. Once again every 2nd or 3rd image is ok and then the bad one's come.
        • JustManuals
          • Jan 2006
          • 9838
          Copiers-Printers-Fax - products new home -
          • kandod
            • Mar 2010
            • 58
            awest486, is the transition sharp-edged (I mean if it is a straight line)? It could be some problem with the device that open and closes the cleaning blade of the IBT cleaning station (if it closes earlier in the YMC toner cycles it will erase the the toner laid in those cycles, and thus only the black will remain).
            manuals4you, please read the question about the Service Manual above, and either give a link or if not willing to help the guy, stop spamming adds.
            • JustManuals
              • Jan 2006
              • 9838
              The link I posted a few hours ago will take you right to the file. It is a .pdf file of the Docucolor 12 Parts & Service manual. 75mb, 1617 pages.
              • kandod
                • Mar 2010
                • 58
                There are only 1632, 3535, 2240 models Parts & Service, those are not same as DC12 (or afair)?
                • Milo Wilson
                  • 499
                  Looks as though the IBT cleaning blade clutch is slipping and letting the blade cam in and out against the belt whenever it wants.
                  • JustManuals
                    • Jan 2006
                    • 9838
                    If you can't follow a simple link, then the manual or anything else isn't going to help you.
                    • kandod
                      • Mar 2010
                      • 58
                      Ha-ha, that was really well hidden ... right in front of my eyes! Thanks!
                      • bojans
                        • 1313
                        Originally posted by hmelo
                        Its not a IBT blade!!! The black is the last color that goes into the IBT! You got Black and no CMY!
                        I think You got a Problem in the IBT Patch.
                        Check all the IBT Assy?
                        It could be IBT Retract clutch. I just to clean it with alcohol, but sometimes you need to replace it.
                        • alex4alltimes
                          • Feb 2010
                          • 68
                          Change the developer bias pwb, check the bias plate (behind developer waste container), check the IBT cleaner clutch (dirt clogging). hopefully it will solve your problem
                          • bebop
                            Re: DOCUCOLOR 12
                            Hello Awest486
                            I have exactly the same problem with my DC12 like yours. Some prints look fine, then two or three come away with that absence of CMY in two inches from outer band of paper. I have also observed that when a bad copy comes out, the colors in the "good" part of the image are somewhat lighter that it should be (ex, reds are more orange like).
                            Please, would you be so kind to tell me how did you solve your problem??
                            Thank you very much in advance
                            Bebop
                            Originally posted by awest486
                            Hello,
                            • kandod
                              • Mar 2010
                              • 58
                              Re: DOCUCOLOR 12
                              Almost allways that kind of problem is caused by a bad IBT cleaner retract clutch (121K17941), so check this first (or replace if a new one is available).
