Xerox WC 7132 with error code 089-311
  • delosangeles
    • May 2008
    • 274
    [Error Code] Xerox WC 7132 with error code 089-311
    Hello everyone
    I have a client with a Xerox WorkCentre 7132 full color copier that displays on power up error code 089-311 I am Ricoh tech so the newer Xerox models are bit of a challenge for us. I would be grateful for any help with a discription of the code and if there is a way to clear it. I don't know how to enter the service modes so I could use your help or if a part would need to be replaced.
    Thanks everyone
    Trade like a tiger sleep like a baby
  • JustManuals
    • Jan 2006
    • 9838
    This Parts & Service manual can now be purchased for $11.77 and downloaded immediately after payment from The Internet's largest collection of manuals
    I'm always looking to trade too.
    Paul@justmanuals.com
    • tech9
      • 216
      The problem is the ibt belt sensor is not reading the silver patches on the edge of the ibt belt. They are either scratched or the sensor is dirty or faulty. Replace patches and clean or replace ibt belt sensor. This normally works for me.
      • delosangeles
        • May 2008
        • 274
        Cool
        Tech9 thanks for that info it's appreciated.
        • MrXerox
          • Sep 2010
          • 76
          ibt belt part number if needed 064K92332
          • delosangeles
            • May 2008
            • 274
            Cool
            Cool, Thanks for that info.
            • eltonmaster
              hello, do not know if you've solved the problem of error 089-311, mais'tem a solution without buying a new belt, is the following, you have to open the front cover of the machine takes all the accessories, such as the photoreceptor , blade cleaning, everything, and then dismantle the whole front just after the fuser strip, and remove the belt, there will appear a few sensors, and wipe them with cotton cloth or sensitive, and then assemble everything back and turn, almost sure it works,.
              • delosangeles
                • May 2008
                • 274
                Really
                Really. I'll try that out. Thanks very much for that info.
                • dexters
                  7132 Error code 89-311
                  I have the solution. Just remove the IBT belt and clean the home position sensors & the silver patch.
                  That's it
                  • delosangeles
                    • May 2008
                    • 274
                    Cool
                    That's it
                    Cool, thanks for that info.
                    • azprint
                      Re: 7132 Error code 89-311
                      That's it
                      I need a replacement silver patch for a Xerox Docucolor 240 IBT belt. Anybody know where I can get one?
                      • delosangeles
                        • May 2008
                        • 274
                        You will have to replace the IBT belt.
                        • azprint
                          Why? Manual shows how to replace patch just no info on where to get one.
                          • delosangeles
                            • May 2008
                            • 274
                            Ok best of luck
                            • azprint
                              Ok best of luck
                              Does that mean you don't know if it can be done?
