System Software for FIERY X-12
  • jk_nvs
    Need Help regarding installation of Fiery X-12.
    I want to know which type of Operating software or Softwares are installed in Fiery X-12.
    Recently I have problems while printing in Xerox DC-12 through
    FIERY X-12, on the LCD display of FIERY - only
    Loading.... appears and fiery is stuck off on that position.
    It Seems that Hard disk of FIERY may be damaged or corrupted.
    SO I want to know the procdure to install the new harddrive and load its system softwares.
    It will be a great help if anyone provides me the procedure to do so.
    Thanks.
  • sidnigj
    • Oct 2007
    • 3
    To restore from backup do the following:
    1) Power down the Fiery and wait 10 seconds.
    2) Press and hold the 4th key on the right side on the UI (user interface) and power on the Fiery.
    3) Continue to hold the 4th key until the UI reads "Install Software", "Restore Backup", "Install Option" and "Start System".
    4) Select "Restore Backup"
    5) Select "Yes" at the following question "Restore backup configuration?"
    6) This will take approximately 15-20 minutes and the Fiery will reboot 3-4 times.
    7) Once the Fiery comes up to Idle you will need to "Run Setup" and reconfigure the settings.
    • jk_nvs
      Thanks for help friend but already tried the way described.
      Thank you very much friend for your reply.
      But, I have already tried the same procedure but no way has been found.
      I have heard from the friend, that for solving this problem. I have to
      reinstall the drivers and software in the Harddrive of the Fiery. If you have the Ghost Image of the Fiery X-12 Version 1.5 SP 2 and if you can send it to me so I will restore the image on my New Drive.
      Or Otherelse If you have any other way, it will be greatly appreciated.
      • TechMate
        • Mar 2008
        • 285
        We have tried to pull out the HDD of the x12 and connect it to a pc. Then use a BOOT record repair software in UNIX mode to repair the MASTER BOOT RECORD of the HDD. The software is available FREE from the internet, just google search and choose the appropriate software. Saves you time from loading the system software off 2 CDs.
        • dksrinivasrao
          how to repair the boot sector using unix mode can u ecplain
          i'm also facing same problem
          • xcopytech
            • Aug 2006
            • 1792
            patch in attachment
            change extension from doc to ps
            • johnner66
              • Mar 2009
              • 265
              x12
              this is deu to the harddisk problem you can get one workerable and clone the hd from the working one and put in is should work for you thanks !!
              • ktxerox
                • Mar 2009
                • 229
                fiery x 12 system software
                dear friends ,
                i have fiery x12 system softwae cd and i can send to you but i also need fiery x12 system software cds for bios verson 1.1 because after reinstallaion of software i am facing problem invalid license message.
                so if anybody have system softwar cds with bios v 1.1 then pllease send. ktxerox@gmail.com.
                • xcopytech
                  • Aug 2006
                  • 1792
                  bios versions are 1.41 and 1.43
                  but you can not install bios with non working fiery.
                  • CopyCat
                    Greetings,
                    Your hard drive may have some bad sectors that may be correctable.
                    I've used SpinRite from GRC.com to correct non-electrical problems on many IDE and SATA hard disc drives over the years.
                    You'll have to pull the hard drive from the Fiery and install it in an Intel based PC, then boot the PC from the SpinRite CD or floppy disk. Under no circumstances try to use Windows to try and repair the drive. It will just make it worse.
                    SpinRite is $89 [ GRC|SpinRite 5.0 to 6.0 ]
                    Be warned that there are some files that appear to be SpinRite "floating" around on the Net, but are really a virus or trojan.
                    Let us know if you're successful or not.
                    • davidj7
                      • 1107
                      let me know if you need the CD's
                      2 CD ver 1.5 for X12.Where are you located
                      a machine is only as good as your tech : source:screwtape ; the scary one
                      • WIWA
                        • Mar 2009
                        • 97
                        Hi, I got the same problem with a customer X12 the problem was the cd rom I disconnet it and problem solve. if dosen't work is the hardrive or corrupted software. If you send me your hardrive and bios i check it for you and upgrade your bios to v1.43 with faci for reasonable fee.
                        Hope this help,
                        Wiwa 72
                        Gonzos build v. 1.0
                        • TechMate
                          • Mar 2008
                          • 285
                          The latest Fiery system software for x12 is v1.5 SP2 (3CDs). It includes all windows patches needed plus mac OS compatibility patches. Just for everyone to know
                          • godfrey
                            Hi I also have the same problem for X 12 fiery, How can i get those three CDs.
                            My email: mukasa_godfrey@yahoo.co.uk.
                            Godfrey
                            • TechMate
                              • Mar 2008
                              • 285
                              You can get a copy from xerox for free if you own the x12 (you are entitled). Otherwise, you may either buy it from xerox (if they allow it) or from an external source
