xerox wc-4118 toner chip resetter, looking for a schematic or instructions to build
  • Enzo
    • Jul 2009
    • 410
    #16
    Originally posted by dinkyoaf
    Just go in order. The chips are labeled. http://img.diytrade.com/cdimg/112689...1278257552.jpg
    Start with GND (BLK) on one side
    Green
    Yellow
    Then Red (VCC) on the other
    and then PonyProg how it works?
    • dinkyoaf
      • Sep 2010
      • 63
      #17
      I've never even heard of PonyProg
      • Enzo
        • Jul 2009
        • 410
        #18
        and you think how can I do to reset the chip?
        • dinkyoaf
          • Sep 2010
          • 63
          #19
          That depends. I'd give RECHARGERSTORE a call and see if the can help you out. They have the devices and software to do it. The procedure varies depending on the chip you need resetting.
          • ago99
            #20
            Enzo
            To reset Xerox DC440 chip you need Xerox90/Xerox01 programmer.
            Read this:
            pa-polewali.net is your first and best source for all of the information you’re looking for. From general topics to more of what you would expect to find here, pa-polewali.net has it all. We hope you find what you are searching for!
            PonyProg dont reset this chip.
            • Enzo
              • Jul 2009
              • 410
              #21
              Originally posted by ago99
              Enzo
              Read this:
              ChipRecharge
              Cartridge chips XC01/X90/X01 Programmer
              I already know the site "Cartridge chips XC01/X90/X01 Programmer" but its equipment is very expensive!
              with chiprecharge.com I can not get in contact so I do not know if it works!
              • Enzo
                • Jul 2009
                • 410
                #22
                Hello. I bought a programmer from Bulgaria (24Cxx, 93Cxx and 25xxx Serial Eeprom programmer E-EPROM su eBay.it Electronic Components, Electrical Test Equipment, Business Industrial) but now I do not know how to do this work! I was suggested to use an adapter to a difference of xerox dc440 and I've got. But where to attack the wires? I am sending you the pictures:
                1) Adapter for my xerox dc440
                http://img24.imageshack.us/img24/2677/immag0054n.jpg
                2) Programmer to Bulgaria
                http://img219.imageshack.us/img219/3336/immag0055g.jpg
                3) My chip
                http://img27.imageshack.us/img27/6390/immag0056.jpg
                • Enzo
                  • Jul 2009
                  • 410
                  #23
                  then I have a clear summary. I want to reset the chip for xerox dc440 and the DC230.
                  1) I have this programmer:
                  2) I removed from an old machine, the part of the connector of the chip:
                  http://img193.imageshack.us/img193/3001/immag0082.jpg
                  3) I have the program and PonyProg KEEProg_USB.
                  Now, with these elements can be able to reset my chip?
                  If yes, how can I do?
                  Can you tell me where I need to attach the 4-wire connector to the programmer?
                  • ago99
                    #24
                    Hardware - OK, but for reset dc440 CRUM you need special software-restorer for XC01/Xerox01/Xerox90 chip.
                    PonyProg and KEEProg_USB software can't rewrite XC01/Xerox01/Xerox90 chip.
                    If you read XC01/Xerox01/Xerox90 chip with PonyProg or KEEProg_USB - killed this chip.
                    XC01/Xerox01/Xerox90 - similar to 24c02 i2c chip. Read datasheet 24c02.
                    Pinout your connector:
                    • Enzo
                      • Jul 2009
                      • 410
                      #25
                      thanks for the reply. I was told I could surely use PonyProg! Now where do I find the program that you say? And where do I attach the wires?
                      http://img696.imageshack.us/img696/8...mag0083bis.jpg
                      • mp4wizzard
                        • Nov 2009
                        • 37
                        #26
                        Sorry the link seems to have changed/ been moved.
                        Tell me what you are after and I'll try and help
                        Eddie
                        • Enzo
                          • Jul 2009
                          • 410
                          #27
                          all links work. however, my problem is where to attach the wires to the my programmer.
                          • mp4wizzard
                            • Nov 2009
                            • 37
                            #28
                            Can you show me the other side please.
                            Plus , do you have the PCB layout........?
                            Eddie
                            • Bhante
                              • May 2009
                              • 45
                              #29
                              On the socket in the programmer for the 2402, connect as follows:
                              GND: pins 1, 2, 3, 4, 7
                              SDA: pin 5
                              SCA: pin 6
                              Vcc: pin 8
                              For the black generic chips, PonyProg can be used without difficulty. Once you have the connection working, make a backup copy on hard disk of an unused chip (one for the DC230, one for the DC440) and use that for resetting the used generic chips each time.
                              • Bhante
                                • May 2009
                                • 45
                                #30
                                SDA: pin 5
                                SCA: pin 6
                                Vcc: pin 8
                                I've just taken a look at the schematic for the 2402 and it occured to me for a moment that it might give faster access putting pin 7 on Vcc instead of GND for use with PonyProg, but looking closer I think it is better to stay on GND. Maybe someone could confirm this.
