Phaser 8560MFP with Bad print quality
  • delosangeles
    • May 2008
    • 274
    [CQ] Phaser 8560MFP with Bad print quality
    Hello everyone
    I have a client with a Phaser 8560MFP with bad CQ. I took off both side covers and could only see the Oil roller and cleaning blade maintenance kit to be easily cleaned. I would have liked to clean the Print Heads or which every device the machine uses to print the image. Is this necessary to correct the bad CQ? And how do I access the print heads?
    Please look over the scans I uploaded. I would be very grateful for any input or advise from fellow technicians, I mostly work on Ricoh equipment so I'm guessing the Maintenance kit high yield [108R00676] should help correct the print quality.
    Thanks everyone
    XEROX PHASER 8560 MFP #4.jpgXEROX PHASER 8560 MFP #3.jpgXEROX PHASER 8560 MFP #2.jpgXEROX PHASER 8560 MFP #1 Copied on glass.jpg
    Trade like a tiger sleep like a baby
  • gregoryk
    hi! i think the problem is the clean cam shaft and you have to replace it !
    • delosangeles
      • May 2008
      • 274
      Really
      Really? I'm not familiar with that item how do you access that part, would happen to have the service manual?
      • gregoryk
        sent me your e-mail in private and i sent you the manual .Have your mail enough space?
