Says the problem is the main drive motor. Tried resetting the drum and fuser unit, the door switches work fine anyone seen this problem before.
Workcentre 133 Error Code 042-325
9 times out of 10, bad main motor
Remove the left rear cover and turn the machine on. You should see the main motor turn for a while during the initialization period, if not, replace the main motor. The part number is 007K88583, and can be found here: 007K88583Michael Rizer Free Technical SupportItem Inc. 800-367-4836 mrizer@iteminc.com -
Update: I was not convinced it was the motor but it was, I changed it the next day and worked great...Comment
