Did you cleaned something? Does code came out of a sudden? I mean no maintance was done or something similar?
This code means that the polygon motor is no rotating. Did you reseat the ribbon cable?
Enter in Dc330 and run 006-030 and listen for the polygon motor, it should start to rotate?
Verify that CR13 on the MCU PWB is lit. If not then start looking first like I sad, cables then ROS then MCU pwb.
Kalindd now exit the pws and restart the machine than unlock and "warming up please wait 4 minutes" after send the work when printed ....code come again...
By the way I look PWB but dont find CR13....now searching again
Your only option is to reseat the cable, and I'm almost sure that cable is the problem.
I had those error lots of times after cleaning ROS, connecting them is real pain. Try it several times and don't give up
Now it is Cyan ROS cable. 6-394 ROS Connect Fail (C).
I think cyan cables are second from top ( inboard to outboard second). Try reseating only those do not touch the others, for now.
did you touch CK ROS box after 6-316 and cable mess up. do you have still 6-316 (maybe 6-317 just come first) i had similar problem but need some more inf about. did you put seal on boxes to prevent further cleanings?
