Xeroc 5020 U2
  • bojans
    • 1313
    Xeroc 5020 U2
    Hi friends
    This machine sometimes pop-up error U2. Subcode is 1. After power off/on it works.
    Any ideas how to solve this problem?
  • JustManuals
    • Jan 2006
    • 9838
    This Parts & Service manual can now be purchased for $11.77 and downloaded immediately after payment from The Internet's largest collection of manuals
    Paul@justmanuals.com
    • pal.xerox
      U2-1 Carriage Module Fail
      BSD-Reference:
      CH6.2 (Figure 2)
      Explanation
      A carriage fault was detected.
      Procedure
      Execute diagnostics [05-22 Move scanner to home position] and [05-23 Move scanner to maintenance position]. (How to Enter the Diagnostic Mode)
      The carriage moves.
      YN
      Check each IIT Carriage connector.
      Each connector is connected securely.
      YN
      Connect each connector securely.
      Check for foreign substances and deformed parts in the carriage.
      None is found.
      YN
      Remove the foreign substances and repair the deformed parts.
      Replace the IIT Carriage (PL 10.3)(REP 10.3.1).
      Execute diagnostics [05-23 Move scanner to maintenance position]. When the IIT Carriage has moved to the leftmost position, press the [Stop] button to put the Carriage Sensor into the blocked state.
      Execute diagnostics [5-11 Home Sensor], and "H" is displayed.
      YN
      Check each IIT Carriage and Carriage Sensor connector.
      YN
      Replace the Carriage Sensor (PL 10.6) and the IIT Carriage (PL 10.3) (REP 10.3.1) in that order.
      Check the Carriage Sensor (PL 10.6 ).
      The Carriage Sensor is installed properly.
      YN
      Install the Carriage Sensor (PL 10.6) properly.
      • bojans
        • 1313
        Thank you very much my friend.
        After this code i got U9, don't know subcode. Paper stops on drum. After cleaning transfer corona, everything seems to work fine.
        Could you list U9 codes, just curious what it means?
        • xeroxsharp
          • Nov 2008
          • 270
          hope this will help!
          U9-0 HVPS Fail
          BSD-Reference:
          CH9.1 (Figure 1)
          Explanation
          A 500 ms cycle of HVPS#ERR=High was detected twice in a row.
          Procedure
          Close the Left Hand Cover and the Front Cover. Make sure that the Drum Cartridge and the
          Transfer Corotron are properly seated. Measure the voltages between P406-2 (
          P/J406) (+)/
          P406-4(+)/P406-5(+) on the AIOC PWB and ground (-).
          The voltages are approximately
          +5VDC.
          Y N
          Replace the AIOC PWB (
          PL 8.1) (REP 8.1.1) and the HVPS (PL 8.2) (REP 8.2.1) in that
          order.
          Execute diagnostics [09-04 HVPS ON (Low Voltage)]. (
          The voltages at P406-2 (
          P/J406) (+)/P406-4 (+)/P406-5 (+) become 0.
          Y N
          PL 8.1) (REP 8.1.1).
          Replace the HVPS (
          PL 8.2) (REP 8.2.1). The problem is solved.
          Y N
          Measure the voltage between P406-1 (
          P/J406) (+) on the AIOC PWB and ground (-).
          The voltage is approximately +5VDC.
          Y N
          Check between J520-1 (
          P/J520) and J406-1 ( P/J406) on the HVPS PWB for a
          short circuit.
          If there is no short, replace the HVPS (
          Compl
          • bojans
            • 1313
            Thank you.
