Replace hard disk DocuColor 250, How to ?
+ More Options
Posts
  • kekkod
    • Aug 2025
    Hello,
    i have a Xerox Docucolor 250 with hard disk of the server that was broken.
    I try to replace with a new SATA 250Gb hard disk, i follow the procedure on the Fiery System CD but the procedure FAIL on the second step.
    Someone can help me?
    Best regards
  • maich4s
    • Mar 2009
    • 86
    what hard disk are you talking about,for the dc250 printer or the fiery controller.these are 2 diffrent harddisks
    • kekkod
      Hello, sorry for my inaccuracy.
      I need to change the hard disk of Fiery Controller.
      • CopyTechOz
        Is this a DC250 Bustled Fiery (mounted on back) or an EXP250 (stand alone fiery)?
        • kekkod
          I try to understand what type is because itsn't mounted on the back, but i think that is DC250 Bustled Fiery.
          On the label is write:
          Printer Controller
          Fiery X3eTY
          Part Number 45052987
          I attach some photos, so you can understand better.
          Waiting your reply ASAP. I've that printer not working from 15days.
          THANK YOU IN ADVANCE AND HAPPY NEW YEAR!!!
          • CopyTechOz
            Yes, that is a Bustled Fiery. Usually mounted on the back of the machine. I always replace Hard Drive with 80GB HD to avoid problems.
            Are you using laptop to download software on the Fiery? Is your anti-virus turned off? Are you using a Crossover cable or regular Ethernet cable? You can email me at oscarj636@gmail.com also.
            • maich4s
              • Mar 2009
              • 86
              hello,just replace the hard disk with 80gb as adviced above then reload the software with a fast laptop.i do it every 4month and all works out well.
              • kekkod
                Hello,
                i've find a 80Gb working HDD. I try to upload software like you write but nothing works!
                The installation process STOP on the second step.
                Visit this link to see a video of the problem :
                I think that is more simple that someone of you give me an "image" that work with your HDD and i put in my hdd
                Stupid idea?
                • maich4s
                  • Mar 2009
                  • 86
                  hello,
                  did you ever fix this problem.just try by getting another set of efi fiery installtion software.let me know the progress
                  • kekkod
                    Problem Solved
                    The problem isn't the Hard disk like i mean, but the bad work of the RAM. I've change it and then the installation process goes well.
                    Now the machine works good!
                    Thank you for your support
                    • BigVis
                      DocuColor 250 EXP250 stand alone fiery
                      Hi There can you tell me what spec HDD should I purchase for the Fiery (i.e. SATA, speed etc.) as I inherited a server with a bust disc and sent it off to be recovered (without taking the details of it!!) I now have a new software suite for the server but no hard drive! Any info will be gratefully received.
                      • InterfaceP
                        • Jun 2013
                        • 488
                        Re: Replace hard disk DocuColor 250, How to ?
                        Not sure about the original size, probably around 160GB. I would recommend a 500GB, I buy them for around $35.
                        I do know it's an IDE I would pop the side open to check the connectors to make sure.
                        I purchase 500GB HDD for about $35. The bigger the better!
                        If you have any problems with the install PM me.
                        • Bjarki
                          • Feb 2025
                          • 2
                          I have an issue with DC250 the internal hard drive went bad, I have replaced it and the machine starts up now without any errors, the fiery rip also comes up with the "00" mark but I cant connect with the machine or print on it, its like the new internal hard drive may not be setup... when a ne hard drive is set there, the printer should put some info on the disk ?
                          or anyone have experience with this?
                          • adriansto
                            • 2388
                            You must initialize the hdd using special boot mode. I think the service manual for dc250 is on net.
