xerox DC 480st problem fuser not available
+ More Options
Posts
  • costou
    • Sep 2009
    • 44
    Hello,
    i have 1 xerox DC460st, and when I start the machine, it say :
    "please wait, machine test in process" then
    "adjustments are in progress" then
    "system is warming up. it will be ready within 4 minutes" then
    "the fuser is warming up. printing may be delayed" then after 2 or 3 minutes :
    "the fuser is not available. call for assistance"
    I change the fuser assembly, but it appears always, I don't know what happened and what I need to do.
    Thanks for your help
  • tech9
    • 216
    Try a new flicker pwb
    • costou
      • Sep 2009
      • 44
      thanks, but i'm very sorry, i don't know what is it or where is it in the machine . Can you help me to find it in the machine ?
      • labanmatte
        • Feb 2011
        • 8
        11 105K24881 Flicker Control PWB
        • ingmaster
          • Mar 2011
          • 39
          I am remove all flicker from all machines pro65, 75, 90 , 470 etc. I am put ssr relay from xerox 1025, can from dc12. How it make, you can to see in the xerox dc265.
          • azehnali
            • Nov 2009
            • 679
            the problem is the fuser relay in the high voltage power supply
            its black color
            same on all the lakes products
            • cantus smetana
              Re: xerox DC 480st problem fuser not available
              I have a Xerox DC490ST whose network controller cannot initialize anymore. Can you help me? Thank you.
              • rockin57rod
                • Mar 2008
                • 73
                please don't hijack this guy's post.....go into user tools and do a reset first
                and the last time I saw that fuser message....it was the wrong fuser in the machine....they all look the same...but are not....
                • azehnali
                  • Nov 2009
                  • 679
                  you need a new hard drive and then need to reload software
                  • Scarecrow
                    • Oct 2010
                    • 234
                    Don't forget the mechanical relay in the same ac distrbution box. Kinda touchy - Doesn't have enough power to pull in the cleaned contacts if you bend them a little too far. Just make sure when you manually actuate the relay, the contacts close with a slight bend. It's usually the problem if the fuser is correct and electrically ok.
