Xerox/Techtronix Phaser 8200
    • 22997
    I don't know what to make of this. I'll welcome any opinions.
    I'm getting white streaks through the cyan part of the image. I've gone to the Support Menu, Eliminate White Streaks and ran the cleaning several times. Here's the weird part: the void area moves around. You know how the boxes are numbered on the cleaner page? So at first cyan is blank from 70 to 110. I run cleaning. Now it's blank from 20 to 50. Run cleaning again. Now it's blank from 55 to 80 and 120 to 130.
    I was under the impression that this is essentially inkjet technology, and that the solid ink just needs a little more heat to become liquid. So a clogged printhead should not have clogs that move around. Could there be air bubbles in there that need to be purged somehow?
    I did follow the destructions, and power the machine off, then power on four hours later and try again. Other than consuming a lot of solid ink, I don't think I'm getting anywhere. Any ideas? =^..^=
  • JustManuals
    • Jan 2006
    • 9838
    What's your email? I'll send you the Parts & Service Manual.
    Paul
      • 22997
      Too late Paul. Don't you remember? It was Monday or Tuesday.
      It's the thought that counts. Thanks. =^..^=
        • 22997
        Anybody? =^..^=
        • jsw2k
          • 95
          I'd love to help you, but these print engines are completely alien to me. Maybe try prying off the "XEROX" badge?
          • CT Copier Repair
            • Mar 2010
            • 304
            Blackcat
            Here ya go
            Random Light Stripes
            One or more color bars are missing on the test page. This is likely caused by
            a weak or clogged Printhead jet.
            Initial Actions
            Run the Eliminate Light Stripes routine from the Control Panel.
            Check the exit path for debris or contamination.
            Troubleshooting Reference
            Applicable Parts Example Print
            Printhead
            Drum Maintenenace Kit
            Stripper Carriage
            Random Light Stripes Troubleshooting Procedure
            Step Questions and Actions
            Yes No
            1
            On the Control Panel, select the Eliminate
            Light Stripes
            function and follow the
            procedure on the printed pages. For 8400
            printers, this step does not include Jet
            Substitution.
            Did this correct the problem?
            Complete. Go to Step 2.
            2
            It may be necessary to repeat Step 1
            up to 3 times if the stripes still appear.
            NOTE
            If there are discolored jets, print the
            solid fill test print in the color with the
            discolored jets. In the following
            example, the yellow stripe has
            discolored jets, therefore you would
            print the yellow solid fill. For
            instructions on printing solid fill test
            prints, see “Black, Red, Green, Blue,
            Cyan, Magenta, and Yellow Solid
            Fills” on page 5-42.
            Discolored jets usually clear after two
            or three prints, using the problem jets.
            3
            Clean the exit path and Stripper Blade with a
            lint-free cloth.
            Yes No
            1
            lint-free cloth.
            2
            Remove the Drum Maintenance Kit and wipe
            the clear plastic wiper blade with a lint-free
            cloth.
            Complete. If the problem
            persists,
            follow the
            steps for
            “Random
            Light Stripes”
            on page 5-3.
            • Scarecrow
              • Oct 2010
              • 234
              Try increasing the voltage to the head - to max - number 256. Run 5 solid color prints - of the color(s) in question - to blow out the crap in the port(s). Set voltage back to normal and run the stripes test, not the routine, to see how it worked. May have to repeat the process again. This process could blow the piezo crystals in the head but the head isn't any good anyway. Haven't blown a head yet, but I have had some ports that were either blown or would not clean out.
                • 22997
                Thanks Scarecrow. I have a parts machine I can scavenge from.
                If this fails, is there any special calibration setup if I swap print heads? =^..^=
                • Scarecrow
                  • Oct 2010
                  • 234
                  Nope, just pop it in. Just be sure to set the head voltage back to default - 128.
                    • 22997
                    OK. I'll post back once I get another chance at this machine. =^..^=
