XEROX PHASER 8400 Printer Error 37,002.47
  • TEKK09
    • 142
    I don't have the service manual for this. Can anyone tell me what it means?
    Thanks.
  • CT Copier Repair
    • Mar 2010
    • 304
    AC power supplied by power sources such as uninterruptible power supplies
    (UPSs) or DC-to-AC inverter systems may not supply correct voltage to
    properly power up the printer. Likewise, other devices sharing the same AC
    circuit can cause AC voltage sags that cause the printer to fail its AC heater
    PEST tests (Print Engine Self Test). The printer may produce any of the
    following disconnected heater errors:
    Printhead jet-stack 37,002.47
    • JustManuals
      • Jan 2006
      • 9838
      Paul@justmanuals.com
      • TEKK09
        • 142
        I have good power and plugged in direct, so looks like I may have a bad heat lamp? I don't know what printhead jet-stack means. Thanks for the response.
        • TEKK09
          • 142
          I couldn't get anywhere without a skematic. Did not find anything obvious, and as far as I can tell the heaters are all okay. Anyone else have any suggestions?
