Xerox WC 7675
  • Guest
    Xerox WC 7675
    I'm looking for a professional service call Xerox WC 7675!
    Software and hardware problems to solve!
    Thank you in advance!
    sjabo
  • labanmatte
    • Feb 2011
    • 8
    Im a xerox technician and analyst, what is your problem ?
    • Guest
      Hello!
      Xerox 7675 is a multifunctional machine which changed the MCU NVM PWB panel.
      Then, the machine says that the panels must be in sync.
      This is only possible through the diagnostic program, and there is a request that generated code is likely to be made through the Xerox hotline to ask!
      Our relationship with our company no xerox!
      Therefore I turned to thee!
      English is not the bread, therefore, forgive me!
      sjabo
      • Guest
        Service manual I got this information!
        As I said there is no xerox support!
        Can you help?
        Serial number and billing data is stored at three locations:
        MCU NVM PWB
        CCM NVM PWB
        IIT/IPS PWB.
        This procedure is used to restore serial number and billing data integrity if these PWBs were replaced incorrectly, or if multiple failures occurred.
        It is not necessary to run this procedure if a single PWB is replaced; if these boards are replaced one-at-a-time, the machine will automatically synchronize the data on the new PWB to match the other two. It is only required to perform the procedure if the removal/replacement procedure is not followed correctly, or if data corruption causes one of the following faults:
        16-801.19
        22-352
        Procedure
        Notify service support.
        Call service support for instructions.
        Complete reserialization form provided by service support.
        Reserialize machine:
        Enter the PWS Diagnostic mode.
        Select the Adjustments tab
        Select the Configuration tab
        Synchronize Serial Number.
        Select S/N Sync (dC132).
        Select Generate Id.
        Call the phone number on the reserialization form and report Unique Machine Identifier.
        You will be given a Password to enter into Submit Password.
        Select Submit Password.
        Serial numbers are now synchronized
        sjabo
        • labanmatte
          • Feb 2011
          • 8
          sorry
          Hello i have been looking in xerox internal servicenet after a program that can generate this code but i cant find it, so you have too call Xerox 2nd level support to get this password, cannot help you,
          Have a nice day!
          Can you help?
          MCU NVM PWB
          CCM NVM PWB
          IIT/IPS PWB.
          16-801.19
          22-352
          Procedure
          Select Generate Id.
          sjabo
          • copymachine
            • May 2009
            • 53
            Call me from Moscow. I'll help you on site. You are not fare. International passport I have.
