Xerox 238 producing blank copies ?
  • Kenny
    • Jun 2009
    • 529
    Xerox 238 when copying produces blank copies ? completly blank ? through doc feeder and also on glass
    any ideas chaps ? fault seems to be interminent ?
    thanks have a nice weekend
    K
  • adriansto
    • 2388
    In administrator mode you are some test for quality of print.
    Make tests to know what is wrong - printer or scanner
    • bojans
      • 1313
      Only time I had this issue was when one of technician before me put the screws on developer station upside down. In that case Dev station cannot come close near the drum, and you get blank copies. Like adriansto suggested you should print something to determine was it only scanner or there is problem with printer too.
      • tech9
        • 216
        Yep dev latching problem push the developer tank against the drum.
        • a.ghafari
          • Sep 2009
          • 46
          I had twice,
          1- the red h.v.p.s wire comes to developer housing,damaged between scanner and IOT near the ROS
          2- faulty humidity sensor.
