116-321 code on DC 3535
+ More Options
Posts
  • vmx12
    • Sep 2007
    • 55
    Machine won't boot, I got a 116-321 code. I did G3 boot setups but didn't help. Before I replace the ESS power board has anyone ran into this and with different resolve.
  • bojans
    • 1313
    At first try changing HDD.
    • vmx12
      • Sep 2007
      • 55
      So when I try to reset the NVM values via the UI by holding down the 0 button and going into diagnostics that way it wont work. has anyone run into this?
      • bojans
        • 1313
        If you asking how to enter UI diagnostic, this is the way:
        - Entering UI Diagnostics
        1. Hold the 0 key on the control panel for five seconds, while still holding 0 press start.
        2. Enter the password from keypad (6789).
        3. Press Confirm
        4. Press the Access button on the control panel to enter diagnostics (indicated by negative screen image).
        - Select the System Settings on the touch screen
        - Select Common Settings
        - Select Diagnostics .
        • vmx12
          • Sep 2007
          • 55
          Yep, tried that just tries to boot normally
          • vmx12
            • Sep 2007
            • 55
            Never mind I'm a d-bag. I was confusing the start with the on/off.
