116-321 code on DC 3535
  • vmx12
    replied
    Never mind I'm a d-bag. I was confusing the start with the on/off.
  • vmx12
    replied
    Yep, tried that just tries to boot normally
  • bojans
    replied
    If you asking how to enter UI diagnostic, this is the way:
    - Entering UI Diagnostics
    1. Hold the 0 key on the control panel for five seconds, while still holding 0 press start.
    2. Enter the password from keypad (6789).
    3. Press Confirm
    4. Press the Access button on the control panel to enter diagnostics (indicated by negative screen image).
    - Select the System Settings on the touch screen
    - Select Common Settings
    - Select Diagnostics .
  • vmx12
    replied
    So when I try to reset the NVM values via the UI by holding down the 0 button and going into diagnostics that way it wont work. has anyone run into this?
  • bojans
    replied
    At first try changing HDD.
  • vmx12
    started a topic 116-321 code on DC 3535
    Machine won't boot, I got a 116-321 code. I did G3 boot setups but didn't help. Before I replace the ESS power board has anyone ran into this and with different resolve.
