Workcentre 5655 turn off print/scan ?
  • mrfuser
    • 1611
    Does anyone know if it is possible to de-activate / turn off the print/scan feature on the Workcentre 5655? I have a client that wants to disable and not show those features on screen if possible.
    Kelly
  • tech9
    • 216
    Try unplugging the firewire pwb this may work it use to on the older wcp45
    • Milo Wilson
      • 499
      You should be able to go into admin features and disable the scan to file
      • bojans
        • 1313
        Go to Tools and set up machine to go Offline.
        • mrfuser
          • 1611
          Okay, so the client won't even see an option for print or scan?
          Thanks all!
          Kelly
          • MrXerox
            • Sep 2010
            • 76
            im not possitive but you may also be able to web into the machine and turn on and off icons on the all services screen.
            • needlesgxe
              • Aug 2008
              • 30
              disconnect the firewire card for the back of the machine and unplug the controller. if they only copy and fax or just copy they dont need the controller.
