Xerox workcentre pro 55 (gets stuck on 75% when network booting up)
  • OfficeCopierRentals
    Office Copier Rentals
    • Mar 2011
    • 21
    When machine is booting up, on the display it go's 25% -50% but it stays stuck on 75% printing network... any help will be appreciated.
    "Discover Copier Solutions" http://alpspecialists.com
  • Milo Wilson
    • 503
    Need to reload network firmware
      • Mar 2011
      • 21
      Wow, how can I get a hold of the firmware? I would need install instructions as well?
      • adriansto
        • 2388
        I think you need PWS for software reload
        • CT Copier Repair
          • Mar 2010
          • 304
          Need a pws. Call a xerox tech
          • Milo Wilson
            • 503
            Yes you need a PWS to install
            • MrXerox
              • Sep 2010
              • 76
              try taking a small flathead screw driver and pull out the ess and press in all connections in the rear of the ess board. from factory some come loose. other that that if you have a spare lvps i would try swapping that to rule it out.
              • pratik_shah
                • Oct 2016
                • 2
                Re: Xerox workcentre pro 55 (gets stuck on 75% when network booting up)
                I have the same issue and iam a novice so what is PWS and what is ESS??
                and how can i get the software needed to reinstall and how do i do it please help me ASAP
                Sent from my Lenovo A7010a48 using Tapatalk
