Xerox C226
  • bmt_hr
    • Mar 2011
    • 128
    Xerox C226
    Hi
    Can somebody help to solve this problem. Fuser unit is new, all four drums are new, toners is new. Transfer belt and waste toner box was clened but problem still there. Tried to change new transfer roller but not difference on print.
  • artphil
    • Aug 2008
    • 155
    Hi,
    Whar about cleaning the mirrors/lasers? Are the Developers in good shape?
    Kind regards,
    Artphil
    • adriansto
      • 2387
      I think this is a print so mirrors is out of problem.
      Led technology there is not a laser beam.
      If a blue edge is the lead edge then seems to be marks from some rollers
      • ingmaster
        • Mar 2011
        • 39
        Where lead edge?
        • simple mind
          • Aug 2009
          • 41
          This is a common pb,check your drum handling gears inside the xerographic cavity,they might be broken(not the teeth but the axle),making them sliping.
          • ingmaster
            • Mar 2011
            • 39
            Problem:
            Banding in one color or more IO/OB every 58 mm ,Cause:
            Developer Drive Gear is broken PL:9.3 Item: 5
            Solution:
            This gear is spared since February 2008
            The Part number is : 007N01597
            Recommendation : If one is broken, you should replace all 4 as its just a matter of time before the others go.
            • simple mind
              • Aug 2009
              • 41
              Originally posted by ingmaster
              Problem:
              Solution:
              You got it buddy !
              • bmt_hr
                • Mar 2011
                • 128
                Maybe you have some pictures of that part?
                • ingmaster
                  • Mar 2011
                  • 39
                  position 5
                  • boris1100
                    • Oct 2012
                    • 12
                    Re: Xerox C226
                    Hello there,
                    I'm new to this forum and I've got the same problem.
                    Can anyone tell me, what I have to do, to change those parts?
                    How can I reach this gear? From the rear-side?
                    Thanks in advance
                    best regards
                    boris
                    • bmt_hr
                      • Mar 2011
                      • 128
                      Re: Xerox C226
                      Hi
                      Are you solve your problem?
                      • boris1100
                        • Oct 2012
                        • 12
                        Re: Xerox C226
                        Hi,
                        no, not yet. Till now I purchased 4 pcs. of this gear.
                        Now i'm not shure how I should repalce those things. I've read, that it should be possible to do this by removing only the cartridges and drums..
                        ..assumed you've got skinny hands... (Ok, my wife has got very skinny hands)
                        otherwise I had to remove which parts of the C226 to fix those problem?
                        I could'nt find any hint in the service-manual
                        Thanks in advance
                        best regarads
                        boris
                        • bmt_hr
                          • Mar 2011
                          • 128
                          Re: Xerox C226
                          You need to pull up a transfer belt, toners and drums. With fingers and a screwdriver can be lifted out.
                          • boris1100
                            • Oct 2012
                            • 12
                            Re: Xerox C226
                            Hi,
                            Ahhh fine! Thank You for this helful information
                            Best regards
                            Boris
                            • bmt_hr
                              • Mar 2011
                              • 128
                              Re: Xerox C226
                              If you need I can make a some pictures....
