DC 3535 004-346
  • sparky1
    • Aug 2025
    DC 3535 004-346
    Hi All, I have a IOT belt home fault on my C3535, I have cleaned the IBT Assy but still will not do a full belt edge learn test and comes up with the error 30 seconds in. Once this has happened cannot redo the test and need to reboot the machine to do the learn test again,
    Any suugestions would be appreciated.
    Cheers
    Mark
  • adriansto
    • 2392
    The silver patch is on the belt ?
    Reset nvm 741-056 to 0
    Look at the cleaner belt assy
    Make sure the cleaner auger rotates free.
    • JustManuals
      • Jan 2006
      • 9838
      This Parts & Service manual can be purchased for $12.77 and downloaded immediately after payment from http://www.justmanuals.com
      Paul@justmanuals.com
      • sparky1
        Thanks for that much appreciated, also when printing the color pictures appear to be missaligned almost two images not aligned any ideas how to sync it?
        • adriansto
          • 2392
          You don't have the manual ?
          Make color registration or max setup and after that check registration clutch.
          • bojans
            • 1313
            Or call technician!
