DC 240 NVM
  • ricardobres
    • 147
    DC 240 NVM
    Hi, I need change the NVM position 700-166 (territory code), but when I want to try change it, it appear a mensage " you can change this value". There are some way to do it?
    I tried to do the download system, but occur an error (16-742) it's a wrong firmware code, but no there others firmwares on the gsn site. Some idea?
  • adriansto
    • 2387
    Have you enabled sw download ?
    • ricardobres
      • 147
      Yes, I have it, and I have the gsn.
      • johnner66
        • Mar 2009
        • 265
        the code is 700-165 and how you load the firmware why you need to load the firmware thanks
        • ricardobres
          • 147
          Because I'm triyng to change the machine region. I changed the 700-165 to Brazil, but I need to change the 700-166 too, but this position is protect.
          • adriansto
            • 2387
            try to change 700-338 nvm. Use UI diag.
            • ricardobres
              • 147
              Thanks, I'll try.
              • ricardobres
                • 147
                I tried change it, but didn't resolv. I tried to change the nvm 616-094, but I didn't access too. It's a information on gsn " incompatible toner cartridge", and it say " Enter Diagnostics on the UI ( * # stop )" , what is it? Other way to enter in dianostic mode? I use " 0 and print", I didn't know other way.
                • xcopytech
                  • Aug 2006
                  • 1794
                  *#stop is work centre machines diagnostic entry
                  docucolor machines use 0+start
                  • ricardobres
                    • 147
                    Ok, if I replace the NVM by someone from another region, I change this values? 700-166 and 700-165? Do you understand me?
                    • alex4alltimes
                      • Feb 2010
                      • 68
                      Re: DC 240 NVM
                      Sorry for the intrusion guys! Hello Ricardo! Could you change the region of the Docucolor 240? If so how? Plese help me. I also need to change region. Thanks a lot.
                      • InterfaceP
                        • Jun 2013
                        • 488
                        Re: DC 240 NVM
                        Try a Forced NVM Initialization:
                        Turn ON the power while pressing the Power Saver key, Stop key and 3 key.
                        Initializes the NVM of the configuration range (Printer Settings etc.) inside the Controller and starts up.
                        Then try changing it...
