Xerox 7655 Color to Color Misregistration
  • azehnali
    • Nov 2009
    • 679
    anybody sean this before and know how to adjust
    the yellow is off by a hairline and DC671 has NG also in the yellow
  • fogra27
    • Mar 2011
    • 29
    run dc 675 RegiCon Setup Cycle Control, check MOB senzor.
    • azehnali
      • Nov 2009
      • 679
      I did the procuder but it did not correct the problem
      does it mean I should change the mod sensor?
      thanks
      • adriansto
        • 2388
        Move the yellovv drum on other position ( color ) and see what is change.
        May be a yellow drum out of specs.
        • azehnali
          • Nov 2009
          • 679
          already did that and even put a new one and it did not correct the problem
          • adriansto
            • 2388
            1.pdf
            If it is like this then check ibt cleaner and do max setup
            • azehnali
              • Nov 2009
              • 679
              very similar only that the yellow is off by a hair line
              will do
              thanks
              • johnner66
                • Mar 2009
                • 265
                try init... the iot mvn after do the adjust the regist...again it work for me here good luck....
