XEROX 700 - HELP
  • yiiya69
    • Apr 2011
    • 14
    [Misc] XEROX 700 - HELP
    I have a Xerox 700 and I have light lines going horizontal across the 17" dimension they are several of them throughout the document. They seem to be appearing in the same place on all copies. Also there is a yellowish banding going in the opposite direction on all copies as well. What to do?
  • Milo Wilson
    • 503
    Re: XEROX 700 - HELP
    Can you post some samples?
    • yiiya69
      • Apr 2011
      • 14
      Yes, here they are. I noticed that the lines don't show as much on a text weight as they do on a cover weight, but they are definetly still there. Thank You.
      • azehnali
        • Nov 2009
        • 679
        run a full sheet if 11x17 with individual CMYK colors
        and narrow it down to a specific color developer ,drum ,ibt charge roller
        • yiiya69
          • Apr 2011
          • 14
          Will do. Thank You.
          • azehnali
            • Nov 2009
            • 679
            where are you located
            • Ianizer
              • Jul 2011
              • 380
              Hm.
              New to 700, but...
              ROS contamination?
              Developer contamination?
              -I
              My name Peggy.
              You got problem?
