Xerox phaser 7300 keeps displaying low toner
  • screwdriver08
    • Jul 2010
    • 160
    I found this printer that a company was trying to throw away. So i took it in hoping that someone could help me identify the problem and hopefully i will be able to fix it. They said that it all started when the printer said that it needed a new black imaging unit, they replaced it, and then it said it was low on black toner, they replaced the toner and it still displays low toner, and also when they removed the black toner, there was spilled toner in the machine right right below the toner, where the black toner sits. Does anyone know how i can fix this? They said it sometimes display no black toner even when they just had put in a new toner a few days ago.
  • JustManuals
    • Jan 2006
    • 9838
    Re: Xerox phaser 7300 keeps displaying low toner
    This Parts & Service manual can be purchased for $12.77 and downloaded immediately after payment from
    Paul@justmanuals.com
    • jtymabel
      • Aug 2008
      • 164
      there are 4 toner flags on the top of the clamshell. they are between the led assemblies. these basically move up because of a magnet and a metal flap that moves in the toner cartridge...there is a foam damper in the optical sensors that register the movement of the flags...i usually just remove the damper (foam) and clean the flags. you will have to remove the cover of the clamshell and remove the board.
      • screwdriver08
        • Jul 2010
        • 160
        Wow...Flags and Clamshell, not really sure what those are but hopefully I will find out. Thanks for the help.
        • Ianizer
          • Jul 2011
          • 380
          Jty.
          I was under the impression that Phaser 7300 was a similar engine to WC7345 series...
          Just a few years working with Xerox gear, so forgive my ignorance.
          Does this have the tube toners?
          I'm thinking of the toner set switches that can pop loose on 7328/35/45.
          Also, the toner cartridge itself can be reset with the little slide tab in the back.
          I may be thinking of an entirely different machine group.
          -I
          My name Peggy.
          You got problem?
          • screwdriver08
            • Jul 2010
            • 160
            xer016198000_1_1.jpgXerox-Phaser-7300.jpg Here is a pic of the Toner and the Printer. I do not know why it keeps saying it needs a new Toner or sometimes Imaging Unit, usually Black.
            • jtymabel
              • Aug 2008
              • 164
              1 333-4383-00 1 Front Panel Assembly
              2 Harness Kit 1 Front Panel Harness
              3 116-1054-00 1 Top Output Eject Sensor
              4 Flag Kit 1 Stack Full Sensor Actuator
              5 116-1000-00 1 Stack Full Sensor
              6 Hardware Kit Exit Rollers
              7 116-1057-00 1 Top Output Tray
              8 116-1549-00 1 Eject Guide Assembly
              9a
              9b
              116-1547-01
              116-0012-00
              4
              4
              LED Head 600 dpi
              LED Head Holder
              10 Hardware Kit 1 LED Assembly Spring
              11
              12 LED Harness Kit 1 Black LED Wiring Harness
              13 LED Harness Kit 1 Yellow LED Wiring Harness
              14 LED Harness Kit 1 Magenta LED Wiring Harness
              15 LED Harness Kit 1 Cyan LED Wiring Harness
              16 116-1548-00 1 Top Cover Inner Frame
              17 116-1024-00 1 Rear Fuser Cooling Fan
              18 Flag Kit 1 Toner Cartridge Sensor Actuator
              19 116-1586-00 1 Toner Sensor Board
              PL 5.1 - Printer Unit Chassis (1 of 2)
              • jtymabel
                • Aug 2008
                • 164
                look at part number 18 and 19.
                you will see the little foam dampers on 18. just remove whats left and clean.
                there is also a screw for the top clamshell on the far left edge thats hard to get to.
                hope this helps
                • screwdriver08
                  • Jul 2010
                  • 160
                  Thank you guys for the Help. I replaced the Flag kit for the black toner and now it works. Thank god they told me they had a old broken Phase 7300 in their storage, so I just took out the Flag Kit and replaced it. Now it is working great. Thanks and hopefully nothing else will go wrong with it, and if it does, I will post it here again..LOL
                  • jcontractor
                    • Aug 2010
                    • 247
                    hope this helps
                    It this flags change could be used to resolve, "reseat imaging unit" message.
                    • jtymabel
                      • Aug 2008
                      • 164
                      it might. give it a try
                      • screwdriver08
                        • Jul 2010
                        • 160
                        I changed the Flag Kit and I didnt get any of those messages saying to reseat the toner. Go ahead and try it.
                        • michel
                          • Feb 2011
                          • 30
                          There's no need to replace the flag kit - simply remove all traces of the old foam damper and add some ballast to the flags to give them a quicker return - you can read my description of the process here: Xerox Phaser 7300 Resource Page - info, tips, free service manual download, resets - Welcome to Michel's Place (michelsplace.fr)
