Xerox WC M24 Need Replace Consumables Display Massage
  • jcontractor
    • Aug 2010
    • 247
    I have one Xerox Workcentre M24 (Similar to Workcentre 1632/2240), it have a display massage that said "Need to Replace Consumables press Machine Status", I went to machine status and there is a Tab "Consumables"; but the machine doesn't allow to see or navigate thru Display Tabs to verify machine consumables. Also I can't navigate to any tab or touch screen options. There isn't any Maintenance Code or any other reference codes.
    Please advice. Any comments will be really appreciated.
  • adriansto
    • 2388
    Re: Xerox WC M24 Need Replace Consumables Display Massage
    Have you administrator rights on this xerox machine ?
    • jcontractor
      • Aug 2010
      • 247
      The machine is from a customer, I found the equipment as I describe. No operations or prints was performed by me.
      • adriansto
        • 2388
        Ask customer if know the administrator password.
        In System Administrator Guide you will find how to setup the machine for you gain access at machine status menus.
        Otherwise you need service manual for this machine.
        • jcontractor
          • Aug 2010
          • 247
          Ask customer if know the administrator password.In System Administrator Guide you will find how to setup the machine for you gain access at machine status menus. Otherwise you need service manual for this machine.
          I have the service manual.
          • adriansto
            • 2388
            In service mode you can reset administrator password or can print service report to see what consumables need to be replaced.
            • jcontractor
              • Aug 2010
              • 247
              I'm planning to verify the higth frecuency maintenence status page.Any aditional suggestion?
              • jcontractor
                • Aug 2010
                • 247
                Touch scren display is defective, it doen t allow confirm pasword to get SM acess.That's the reason witch I can't acess the consumables TAB at Machine Status Screen.As I can't witch consumable is needed the machina doesn't responde in any way.It can't be use as printer either.
                • adriansto
                  • 2388
                  Then you can use PWS to comunicate with machine.
                  • jcontractor
                    • Aug 2010
                    • 247
                    It could be managed by network connection?
