Running DC 5000 on single phase 240
+ More Options
Posts
  • Milo Wilson
    • 503
    Can someone lead me to a source to convert 240 single phase power to 240 two phase power to run a DC 5000.
    I have a dc 5000 I'm installing in Bangladesh and they run on single phase 240 and the machine is two phase 240.
  • seansbar
    • Dec 2010
    • 198
    Re: Running DC 5000 on single phase 240
    There really is not a double phase. Here in the USA, its Single phase or Three Phase. There is a capture from the CED. Single phase everywere.DC5000.JPG
    • davidj7
      • 1107
      milo: i assume you have come to a solution
      a machine is only as good as your tech : source:screwtape ; the scary one
      • Milo Wilson
        • 503
        Yes Davidj. Thanks anyway. I found that the 5000 will run on 240v "single" phase. Just make sure you tap the incoming power supply to the correct level. As a side note...make sure that you also adjust the UI dell PC to 230 before you let someone power it on...lol
