xerox wc pro 3545
  • jtymabel
    • Aug 2008
    • 164
    xerox wc pro 3545
    Need help getting into service mode on a Xerox wc pro 3545
  • adriansto
    • 2391
    Re: xerox wc pro 3545
    You need PWS and WCPS Diagnostic Navigator to do that.
    What's your problem ?
    • jtymabel
      • Aug 2008
      • 164
      Originally posted by adriansto
      You need PWS and WCPS Diagnostic Navigator to do that.What's your problem ?
      Just replaced the belt cleaner and the belt. I just need to reset the counter for both
      • adriansto
        • 2391
        There is not local UI diagnostic mode on this xerox machine. Only with WCPS Diag. Nav.
        If you change the IBT belt you also need to make color registration which include belt edge learn. Otherwise you may damage the belt.
        I think you have service manual for this xerox box.
        If you need more informations this is my mail:
        stoadis@gmail.com
        • jtymabel
          • Aug 2008
          • 164
          Thanks for the reply.I will look for the diagnostic software and manual.
          • azehnali
            • Nov 2009
            • 679
            if you need pws and diagnostic software I have it
            are you in CA
