xerox 4595
+ More Options
Posts
  • azehnali
    • Nov 2009
    • 679
    xerox 4595
    does anyone have 4595 machine software , firmware
  • ktxerox
    • Mar 2009
    • 229
    Re: xerox 4595
    yes i have pm me at ktxerox@gmail.com
    • djwhoo
      • Aug 2013
      • 117
      Re: xerox 4595
      could you help me out with a 10-330 fault. ive replaced the fuser motor, pressure roller and the heat roller. ive been playing with the nip adjustment but i will intermitently fault out. any thoughts?
      • dorez
        • Feb 2013
        • 73
        Re: xerox 4595
        You have already replaced the defective product; Fuser Motor. As error code 10-330 indicates Fuser Motor Rotation Failure.
        I would suggest replacing the MCU PWB as you seem to still have to problem after replacing the Fuser Motor. MCU PWB Part# 960K17980
        Hope This Helps
        • Exok
          • Jun 2011
          • 750
          Re: xerox 4595
          Did you replace the fuser drive motor or the whole drive assembly? I've had worn bearing in the drive assembly cause fuser drive malfunctions. I've also seen the pin in one of the drive shafts in the drive assembly snap in half. (very hard to detect this while still installed) This will cause a problem off and on. If the "half pin" shifts to center itself on the shaft it can not turn the drive coupling. If the pin moves to one side or the other it then can turn the coupling.
          Does your machine have the cleaning blade assembly installed under the press roller? I've seen these blades get caked up with toner gunk enough that it slows down the fusing unit tripping the 10-330 code.
          Did your replacement fuser rollers come with bearings? If not, replace the bearings.
