Docucolor 5000 prints with deleted trail edge
  • safas
    • Jul 2011
    • 40
    Hi, I'm trying to fix a problem I'm having with a Docucolor 5000, whenever I print any heavy stock, the prints would come out with a partial print on the trail edge. It looks like the page is curled, but from experience, this happens on the lead edge, but not the other way around.
    This happens when I print on any size paper and the deletion is in the same spot from the edge of the paper on all the prints, except if I print on light weight paper.
    Please any help is appreciated
  • kalindd
    • Jun 2008
    • 192
    Re: Docucolor 5000 prints with deleted trail edge
    If you post a scan it would be helpful.
    From your explanation I think that you suffer from problem so called "trail edge flip" defect.
    This usually happens on stiff and non-recommended paper.
    First try to lower the 2nd transfer value, this may fix it.
    Second to try is, open your diagnostic sw and search through transfer nvms. Search for TES NVMs this is the value you need, depending on paper weight/type and print coverage you can change the 2nd transfer voltage for the trail edge.
    Good luck.
    • safas
      • Jul 2011
      • 40
      I believe this may be my problem, is there anything I can do about it if I don't have the pws?
      • kalindd
        • Jun 2008
        • 192
        Yes, lower 2nd transfer voltage from user interface.
        • safas
          • Jul 2011
          • 40
          I've attached the image of the scan
          I've tried the various settings for the 2nd bias transfer roll at either 50% or 150% and it didn't make any difference.
          The paper that's used is a 100# gloss cover, if that makes any difference.
          • kalindd
            • Jun 2008
            • 192
            Nice pic, but it will great if you mark where lead and trail edge are or point where is the problem.
            • safas
              • Jul 2011
              • 40
              sorry but the bottom is the trail edge of the page (last part to come out of the machine)
              • kalindd
                • Jun 2008
                • 192
                Is this the problem?
                If yes, this is not "trail edge flip/smear" this something else.
                • safas
                  • Jul 2011
                  • 40
                  sorry the area with the black circle is what I'm talking about
                  • adriansto
                    • 2383
                    If you use correct settings of paper size in your computer that match the paper size in your machine then the error goes from registration and magnification of the copier/ printer. You need to do registration series and after that make little adjustements for paper weight you use for those prints.
                    • kalindd
                      • Jun 2008
                      • 192
                      Brown is going to purple, am I right?
                      In some cases there is nothing you can do about it. But I think you need to call a tech, you may need a new 2nd transfer unit or only adjustment.
                      Both cases you need either PWS tool or tech.
                      Good luck.
                      • safas
                        • Jul 2011
                        • 40
                        I believe it could be my 2nd BTR, since that hasn't been replaced since we've had the machine installed.
                        or maybe increase the voltage on the unit, but doesn't that make it wear out faster?
                        • adriansto
                          • 2383
                          Sorry but on my monitor I cant see the brown color going to purple color.
                          Anyway if this is defect before change 2nd BTR you need first to do a powerful clean of 2nd BTR assy make adjustements and try to print again. But without PWS and service manual the right way to do that is to call a tech. Check your pm.
