Xerox 214 Copier Error Code U9
  • vetteguy
    • Jun 2025
    [Error Code] Xerox 214 Copier Error Code U9
    Hi Folks,
    I have a Xerox model 214 desktop coper which continues to send a U9 Error Code. I can copy a couple of pages and then I have to turn the copier off and on when the U9 Error Code appears in order to make additional copies. Can anyone tell me what causes a U9 Error Code? Thanks
  • tech9
    • 216
    Re: Xerox 214 Copier Error Code U9
    The High Voltage Power Supply detects an over-current or over-voltage condition in the power supply output.
    Check door contacts
    • livewire
      • Sep 2011
      • 608
      Hi vetteguy,
      check Transfer corotron and corotron wire.
      Replace Transfer corotron if you have a new one, or with other.
