WorkCentre 5645 03-XXX error
  • livewire
    • Sep 2011
    • 608
    Hi everybody,
    I have a little problem with WorkCentre 5645 copier only.
    See attachment file to view Fault History Report.
    The error codes are:
    03-350 The IOT has detected no response from the tray 1 and 2 control PWB to the ping request.
    03-315 The image processing PWB has performed a crash recovery procedure.
    03-300 The image processing PWB to IOT communications have failed.
    08-151 The trail edge of the paper was late to the registration sensor after the registration clutch, CL08-070 on.
    03-371 The fuser CRUM communications have failed.
    03-372 The xerographics CRUM communications have failed.
    This is a very strange problem.
    Todey a was made only few copies from tray 1 (A4SEF), tray 3 and tray 4 (A4LEF).
    I have paper jam at area 1, 3 and 4.
    Any supposition?
    Thank you.
  • adriansto
    • 2388
    Re: WorkCentre 5645 03-XXX error
    Seat and reseat the xerographic and fuser modules. Clean the transfer/ detack assy and try again to make copies. First of all power off the machine.
    • livewire
      • Sep 2011
      • 608
      Hi everybody,
      the case is done.
      thank you to adriansto to respond.
      There is a short circuit on yellow cable between (PJ142 pin1) Main drive PWB and Xerographic module CRUM.
      See attachment pictures.
      Sorry for low quality.
      Cheers!
      • chand226
        • 38
        what happened after short circuit ?
        Originally posted by livewire
        Hi everybody,
        the case is done.
        [ATTACH=CONFIG]12049[/ATTACH] [ATTACH=CONFIG]12050[/ATTACH] [ATTACH=CONFIG]12051[/ATTACH]
        Cheers!
