Code Fault 091-311 Xerox 242
  • pitaspotpr
    • May 2025
    Hi everyone... i have a code 091-311. In one forum said that change the cc cleaner motor. I change this part and printing 100 copies. I power off the machine because i leave and 2 hour later, turn on the machine and give the same code. Any idea why give me the same code?
  • johnner66
    • Mar 2009
    • 265
    Re: Code Fault 091-311 Xerox 242
    check your cc cleaner motro try change the bk drum charge assy if same then lookup for the cleaner motro good luck
    • pitaspotpr
      CC Motor is good. I veified in another machine. I think that is the sensor of the assambly. You recommended me that change the assambly?
