Xerox Phaser 3300 image problem
  • savi0r
    • Sep 2010
    • 363
    Hi all. I have this machine in service and when it prints or copies, the copy is very light. I changed the drum on the cartridge and nothing has changed. Still, i notice that some parts of the copy can be seen more clearly and have contrast. I cleaned the HVPS and contacts, but still the same thing happens. Btw, i cleaned the laser unit as well. Any other suggestions?
  • Tropix
    • Jul 2011
    • 45
    Re: Xerox Phaser 3300 image problem
    Try to change a cartridge unit there is a developer, he can be a problem if you replaced the drumand cleaned the lsu
    • savi0r
      • Sep 2010
      • 363
      I'll verify today the mg roller and doctor blade. I'll come back with details. Thanks.
      • adriansto
        • 2387
        You can post here an configuration report from machine to see how the print is
        • savi0r
          • Sep 2010
          • 363
          Hi all. I've attached 2 scanned pages of the configuration report of my phaser 3300. You can see clearly how it lacks contrast and density. I await your suggestions. Thanks
          • adriansto
            • 2387
            If you added toner in cartridge then may be a wrong toner.
            First of all measure if a drum is grounding.
            Measure the charge voltage on cilinder = -700 volts and magnetic roller bias voltage = -250 volts.
            • savi0r
              • Sep 2010
              • 363
              Hi. Thanks for the advice. But how exactly do i measure what your talking about?
              • savi0r
                • Sep 2010
                • 363
                Hi all. I'm still having the same problem with this machine. The thing is that on the drum the image looks perfect, but on paper it looks very faded. I tried with another transfer roller, from a xerox 3100, but without the little gear on the end, and still no improvement. Any other ideas?
                • JustManuals
                  • Jan 2006
                  • 9838
                  Paul@justmanuals.com
                  • xeroxsharp
                    • Nov 2008
                    • 270
                    I think you need new copy cartrige and the problem is gone.
                    • savi0r
                      • Sep 2010
                      • 363
                      HI. Thanks for your reply. But my question is : how do you explain that the image forms corectly on the drum of the cartridge? And what part of the cartridge do you thing is causing the problem? If the image is ok on the drum, and on paper it looks faded, then logically it's a transfer problem. How do you explain this?
