xerox dc250, touchscren problem
+ More Options
Posts
  • vaian
    • Jul 2011
    • 8
    Greetings to everyone,
    After a day I used the printer when I let go again I could not use the touchscreen. All buttons on the monitor works but touchscreen does not receive any order. Room temperature is likely to be a problem? When I restarted it the next day were about 16 to 17 degrees. If you tell me which is the temperature range in which you can use this printer.
    Thank you
  • bojans
    • 1313
    Re: xerox dc250, touchscren problem
    This is very common problem with those lcd's. First try to calibrate touchscreen (1+3+0 and power on). There is a pen behind screen. Touch intersections and pray that it work. If that doesn't help you'll have to change it.
    Good luck
    • vaian
      • Jul 2011
      • 8
      Thanks for the reply.
      Please tell me if you know which is the room temperature range that can work this printer. You may have deteriorated due to low temperatures?
      I tried this method of calibration and does not work. Touchscreen not receive any order.
      • bojans
        • 1313
        Environment temperature range of 60-75 deg. F, (16-24 C) , Relative Humidity range 20-40%
        source:google
        • vaian
          • Jul 2011
          • 8
          thanks for information
          • bojans
            • 1313
            you're welcome
