Xerox workcentre 7132 "cartridge error"
  • screwdriver08
    • Jul 2010
    • 160
    I have this xerox workcentre 7132 that i had been working on, with the help of the people on this forum i was able to fix it, i have been using it for a long time. Then it says that it is out of yellow toner, so my friend went ahead to change the toner with a new one, but everytime we do that a message shows up "cartridge error" we have taken the toner out and installed again many times but it still says "cartridge error". Does anyone know what needs to be done?
  • adriansto
    • 2388
    Re: Xerox workcentre 7132 "cartridge error"
    If was used correct partnumber for yellow cartdrige then you need to do IOT NVM initialization.
    • screwdriver08
      • Jul 2010
      • 160
      Thanks, can you also help me by telling my how I should do that?
      • adriansto
        • 2388
        Service manual is a must for a tech.
        • screwdriver08
          • Jul 2010
          • 160
          I do have a service manual for the Workcentre 7132, it's just that I don't really know what to do when dealing with IOT NVM initialization
          • adriansto
            • 2388
            Read the manual chapter 6 and you'll see.
            • xander
              Replaces the yellow developing tank.
              • screwdriver08
                • Jul 2010
                • 160
                Ok, before I did the IU, I put in the old Yellow toner cartridge that I am supposed to replace, and it says %19 remaining and it works. But whenever I put in the NEW Yellow toner cartridge, the error comes up again. I have checked the box of the new toner and on it it says
                "Xerox
                Yellow Toner
                Workcentre 7132, 7232, 7242"
                I compared the two toner cartridges and they both look the same except for the labels on it for the Reorder/Recommander #
                The old Toners Reorder # is
                BLACK 006R01266
                YELLOW 006R01267
                MAGENTA 006R01268
                CYAN 006R01269
                and The New Toner
                Black 006R01317
                YELLOW 006R01263
                MAGENTA 006R01264
                CYAN 006R01265
                So is the new cartridge bad? I have already ordered a set of these Toners, Black Yellow Cyan and Magenta
                • adriansto
                  • 2388
                  No the cartdriges are not bad but you need to put in your machine toner with same partnumber like the old one.
                  • screwdriver08
                    • Jul 2010
                    • 160
                    Am sorry but I do not really understand what you mean by that.
                    I did also take the Toner to another Office that has a Xerox workcentre 7132, I tried the new Yellow Toner on it and still it displayed the cartridge error.
                    • adriansto
                      • 2388
                      Your new toner have partnumber for Europe region and you have in machine toner for US region.
                      • screwdriver08
                        • Jul 2010
                        • 160
                        So Do I have to order some new toners than? If not then how can I make the machine recognize the Toner from Europe? And work with it?
                        • screwdriver08
                          • Jul 2010
                          • 160
                          • tech9
                            • 216
                            some machines have different billing plans sold / metered
                            Black Toner Cartridge Metered
                            006R01262 / 006R01317
                            Worldwide
                            Yellow Toner Cartridge Metered
                            006R01263
                            Worldwide
                            Magenta Toner Cartridge Metered
                            006R01264
                            Worldwide
                            Cyan Toner Cartridge Metered
                            006R01265
                            Worldwide
                            Black Toner Cartridge Sold
                            006R01266 / 006R1318
                            NA/ESG
                            Yellow Toner Cartridge Sold
                            006R01267
                            NA/ESG
                            Magenta Toner Cartridge Sold
                            006R01268
                            NA/ESG
                            Cyan Toner Cartridge Sold
                            006R01269
                            NA/ESG
                            006R01270
                            DMO-W/XING
                            006R01271
                            DMO-W/XING
                            006R01272
                            DMO-W/XING
                            006R01273
                            DMO-W/XING
                            Black Toner Cartridge Neutral
                            No Part #
                            Shipped with m/c
                            Yellow Toner Cartridge Neutral
                            No Part #
                            Shipped with m/c
                            Magenta Toner Cartridge Neutral
                            No Part #
                            Shipped with m/c
                            Cyan Toner Cartridge Neutral
                            No Part #
                            Shipped with m/c
                            • tech9
                              • 216
                              Toner cartridge
                              Type
                              NVM
                              740-049
                              read only
                              Geographic area NVM 740-047 Read Only
                              NA/EU = 3
                              DMO-E/W = 12
                              All the world (worldwide) = 512
                              Metered = 3
                              NA
                              NA
                              Worldwide Metered
                              Sold = 2
                              NA/ESG Sold
                              DMO-W/XING Sold
                              NA
                              Neutral= 31
                              NA
                              NA
                              Worldwide Neutral
                              These NVM values cannot be changed once set by reading original toners they can only be changed by a CRUM conversion KIT,
