Does anyone know where I can get a replacement reflective patch for the IBT on a Xerox 240 Docucolor?
Need Reflective Patch for Xerox Docucolor 240
Re: Need Reflective Patch for Xerox Docucolor 240
Read this topic:
http://www.copytechnet.com/forums/xe...ay-center.html
You need pws and service manual to resolve this defect
There is the patch replacement code but differ from region.
I ask again where are you from ?Comment
You can cut a square piece of the aluminium foil that the drum is packed in and stick with super glue where your patch was , works fine for mea machine is only as good as your tech : source:screwtape ; the scary oneComment
It is the same type of protective plastic that comes on new products with smooth shiny parts and whatnot. Meant to be removed.
It will still work with the protective plastic, but the patch is "thick" that way and eventually starts to rip off. I've had machines from the factory come with the plastic not removed from the patch. After about a million prints you'll start getting "belt home position failure" and whatnot without frequent (slightly tedious) cleaning. With the plastic removed, I've had the patches last over 3 million prints. (Basically, they outlive the belt itself.)Comment
I'm certain that when I bought it, that was the part number. But it's been a while, so try changing the 1 at the end to a 2, for example. There may have been a revision, causing the part number to increment. I bought them direct from Xerox's parts department. They can usually help you find revised part numbers, as the old part numbers are generally notated with the current part number.Comment
Thank you for your reply.
I'll call XEROX tomorrow.Comment
I believe that part number is for the European market. Maybe!
I just found these two sources:
UK
http://www.amazon.co.uk/Sparepart-Xerox-IBT-Seal-604K45000/dp/B007NFD3EU
USA
http://www.partsdrop.com/repair-patch-xerox-dc250-style-p-3177.html
Hey try this work for me make an reflective patch out of aluminum tape used on air ducts very sticky or Xerox reflective tape olds guys knows what it its used on 1045 machines ADF sensor will last for the rest of belt life.
Hope this help,
Wiwa 72 Gonzos build V.1.0Comment
