in pro 32 the display is blank
  • ravilanb
    • May 2011
    • 24
    pro 32 display is blank but the led indicator keep blinking.if somebody can help.thanks in advance.
  • azehnali
    • Nov 2009
    • 679
    Re: in pro 32 the display is blank
    do you have pws software?
    • ravilanb
      • May 2011
      • 24
      i have diagnostic navigator can that be of use.
      • azehnali
        • Nov 2009
        • 679
        yes plug it and see what the error code is
        might be the battery
        • adriansto
          • 2383
          Did you try to upload or upgrade software before UI goes blank ?
          • ravilanb
            • May 2011
            • 24
            i tried to connect diagnostic navigator thru usb but that didnot work.possibly iit software needs to be uploaded but i dont have it.
            • adriansto
              • 2383
              Where are you from ?
              You can try to connect with altboot on serial port of the net controller and see what is there.
              I think you have defective VPC board from net controller.
              I ask you again if the UI goes blank after you reload or upgrade software /firmware ?
              • ravilanb
                • May 2011
                • 24
                i am from jaipur,india.i did nothing regarding software/firmware upload,as i dont have it.it was at customers place ,in the morning when he switched on m/c didnot work and this problem was there.
                • adriansto
                  • 2383
                  Ok
                  Which is your mail to send you some technical bulettins.
                  • ravilanb
                    • May 2011
                    • 24
                    you can mail on tc_jpr@yahoo.com thanks for your cooperation.
                    • ravilanb
                      • May 2011
                      • 24
                      thanks for the technical bulletins .m/c repaired.I removed the cards from controller, cleaned their connectors and refitted them.Then on switching on the m/c display start giving dots for which I used 108 &105 in navigator,and the m/c is up. thanks again for your help.
                      • adriansto
                        • 2383
                        I am glad you resolve the machine fault.
                        • azehnali
                          • Nov 2009
                          • 679
                          make sure you never turn the copier because the battry sounds like it might fail
