RESET DRUM-FUSING
  • command
    • Nov 2011
    • 4
    [Misc] RESET DRUM-FUSING
    How can i reset drum and fusing unit counters on xerox wcm175
  • adriansto
    • 2387
    Re: RESET DRUM-FUSING
    With a long screwdriver.
    • command
      • Nov 2011
      • 4
      WHAT DO YOU MEAN
      • adriansto
        • 2387
        Originally posted by command
        WHAT DO YOU MEAN
        • command
          • Nov 2011
          • 4
          And what can i do with that? Where can i put it?
          • adriansto
            • 2387
            You work with 'that'. Remove drum module and fuser module and change the crum ( chip ) located behind of every module with new crum.
            Also you need 'that' to remove screws on top of fuser module and replace the web material if you want fuser work for a long period of time.
            All operations need ' that'
            • command
              • Nov 2011
              • 4
              HA HA HA .I'm asking how can i reset the crum ( chip)
              • adriansto
                • 2387
                Buy new ones
